Message 1 of 26
Billion 8800NL failing setup
My old Openreach box stopped receiving DSL signal (light not on), so having verified it was not the cable, I got a Billion 8800NL to replace it. Currently I've not tied setting it to modem only, as I want to get it correctly set up first.
The problem I am having is that I cannot get it to connect to Infinity.
DSL light is on and solid green
I get into Easy Sign On screen without issue
Select DSL, PTM(VDSL), and PPPoE options
I have tried several different username/password combos:
bthomehub@btbroadband.com with no password
Above, with btinternet as password
bthomehub@btinternet.com with no password
No other settings changed.
All the above result in "FAIL! WAN Setting is not successful, you can do this procedure again"
Does anyone have a suggestion as to what might be going wrong?
25 REPLIES 25
Message 2 of 26
Re: Billion 8800NL failing setup
if it was the openreach modem that no longer works then you need the router set up on modem/router mode and the rj11 cable connected from wall socket to dsl connection on hub
Message 3 of 26
Username is homehub@btbroadband.com and password BT (if router insists on one). Is there an option to set VLAN, if so set it to 101.
Message 4 of 26
Thanks both. Cable set up as imjolly suggests, replacement is by default modem/router configuration.
Vlan confirmed set to 101. Changed username to your suggestion licquorice.
No dice just applying those settings, nor on reboot
Message 5 of 26
did this guide come with router  http://support.billion.com/_Internet/qsg/BiPAC-8800NL-QSGEN.pdf
Message 6 of 26
Bit of a long shot, change authentication method from auto to Chap and see if that works.
Message 7 of 26
@imjolly Yes, the guide did come with it, and has been followed. Several times in fact!
@licquorice Thanks, sadly no difference - I still get a big red FAIL at the end of setup
Message 8 of 26
I'm afraid I'm out of ideas then. You could try setting it up in bridge mode and let the hub deal with the PPP session and see if that works.
Message 9 of 26
Thanks for your help. How do I set it to bridge node?
One other piece of info I've just stumbled across - WAN status page shows pppoa0 stats as connecting; ppp1.1 as Unconfigured; this despite having ppp1.1 as Selected Default Gateway interface and DNS server interface.
Message 10 of 26
Just tried setting it to Bridging mode. Still fails
