IanGralda
Message 1 of 5
Blocking BBC iPlayer
Hi All,
Does anyone know of a way I can block BBC iPlayer from being used within my Broadband connection?
4 REPLIES 4
john46
Message 2 of 5
Re: Blocking BBC iPlayer
why are you trying to block Iplayer
Liam_
Recognised Expert
Message 3 of 5
Hi, you could try blocking the IP address in your routers firewall or in the hosts file of windows PCs.
IE: add the line 127.0.0.1 212.58.246.54
Or the line 127.0.0.1 www.bbc.co.uk/iplayer
You may end up blocking more of the BBC site than you intended though. Still worth a try you can always undo the changes if you don't like the result.
Ectophile
Distinguished Guru
Message 4 of 5
See http://www.tvlicensing.co.uk/check-if-you-need-one/topics/bbc-iplayer-and-the-tv-licence
From September, you need a TV licence to watch any programmes on iPlayer.
john46
Message 5 of 5
Thanks for that I had forgotten that subject
