OldGold
Message 1 of 3
Bluetooth.
Have tried repeatedly to pair my Touch2 with Nuvi Gps navigator using Bluetooth without either one seeing the other, Bluetooth switched on on both.
Worked Ok using the 620.
Anyone else had this and resolved it?
Ray
Ray.
2 REPLIES 2
AlunH
Message 2 of 3
Re: Bluetooth.
The only thing I can think is to go through the procedure again and make sure BT is on and discoverable.
Go to Settings, and select Communications.  From here, tap Bluetooth (where it says Bluetooth, not the on/off switch to the right).  Tap the left hand tab (the one with all the cogs)  Look for the Binoccular icon that says "discoverable" and tap on that and set visibility to Always on, or Visible for 60 seconds.  Click done, then go through the Add a device tab and try pairing again.
Cheers
Alun
"Can a leopard change it's shorts?" - T Prattchet
OldGold
Message 3 of 3
Re: Bluetooth.
Thanks Alun, that did it, I had Bluetooth on but not discoverable.
Ray
Ray.
