Anonymoose
Message 1 of 19
Brand new Home Hub 5 restarting way too much
So a few days ago, I got a brand new Home Hub 5 delivered and after a few restarts (of what I assume were firmware updates and the usual stuff) everything was fine for a day or two. However since yesterday morning i've been getting frequent reboots from my hub, to the point where it's really difficult to use. I've had my home hub reboot at LEAST 8 times so far today, probably more that I haven't noticed.
Does anybody know what is causing this? There are no reported problems in my area and the firmware seems to be up to date. We are moving on to Infinity tomorrow so maybe that has something to do with it, but I don't see why.
18 REPLIES 18
imjolly
Message 2 of 19
Re: Brand new Home Hub 5 restarting way too much
is there any noise on quiet line test  dial 17070 option 2 should eb quiet and best with corded phone
is infinity self install or engineer?  moving to infinity should not cause resetting problem
Anonymoose
Message 3 of 19
There is no noise and it's self install.
I'm also assuming that it is rebooting but that may not be the case, the light keeps flashing orange and all wi-fi devices get disconnected until the hub light turns blue.
imjolly
Message 4 of 19
are you using the test socket especially if you have extension sockets in other rooms  did you get new filters to use?
Anonymoose
Message 5 of 19
What is the 'test socket'? Also everything was replaced with the new hub, wires, filters and power supply.
imjolly
Message 6 of 19
Anonymoose
Message 7 of 19
Ahh yes I we are, is that a problem?
imjolly
Message 8 of 19
no that should be your best connection
Anonymoose
Message 9 of 19
Ahh i see, so you have no other ideas 😕
imjolly
Message 10 of 19
did you do a factory reset after the firmware updated?
are you able to post any stats from the hh5  troubleshooting then helpdesk
some things to check for interference
interference causes
