Anonymoose
Message 11 of 19
Re: Brand new Home Hub 5 restarting way too much
I did not, would it not then need to do another firmware update?
1. Product name: BT Home Hub
2. Serial number: +068343+NQ44624181
3. Firmware version: Software version 4.7.5.1.83.8.204 (Type A) Last updated 28/03/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:00:24
6. Data rate: 1091 / 13776
7. Maximum data rate: 1092 / 13888
8. Noise margin: 6.6 / 6.3
9. Line attenuation: 16.4 / 34.2
10. Signal attenuation: 16.6 / 32.4
11. Data sent/received: 0.0 MB / 0.0 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID: BTHub5-WQ8T
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-WQ8T
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 18:1e:78:13:ad:ee
24. VPI/VCI: 0 / 38
25. Modulation: G.992.5 Annex A
26. Latency type: Fast
27. Software variant: AA
28. Boot loader: 1.0.0
Anonymoose
Message 12 of 19
I did not, wouldn't the firmware need to install again if I did that?
13. BT Wi-fi: No
24. VPI/VCI: 0 / 38
imjolly
Message 13 of 19
no a factory reset will not change the existing firmware so no update required
connection time is on 24sec so was that a manual reset?
I am surprised if you have been dropping connection as often as you say that the noise margin is still about normal 6db and also that your latency is fast.  normally first thing DLM will do with dropping connect is to change latency to interleaved
Anonymoose
Message 14 of 19
No it had just crashed and it's happened several times since. Yeah it is really unusual, while everything is up it's running smoothly and pretty quickly, but the constant reboots are making it near unusable.
Anonymoose
Message 15 of 19
Still having the same issues
john46
Message 16 of 19
have you carried out a factory rest yet ?
Anonymoose
Message 17 of 19
Yes I have, it didn't solve the issue.
It SEEMS to be more frequent when streaming video, maybe pulling large amounts of data has an impact. Although that may just be a coincidence.
Anonymoose
Message 18 of 19
And now this morning I seem to have NO broadband and NO phone for way longer than I should... Sure glad I upgraded...
imjolly
Message 19 of 19
if it is causing problems with your phone and broadband then sounds more like a line fault than just a hub fault.  I would phone customer services and get engineer visit
08001114567
