Message 1 of 31
Brand new Smarthub 2 will not accept default password
I there any workaround for this problem. I tried twice on my mobile and once on my tablet - all three times I get the password error message. The hub connects perfectly with ethernet, but the wifi side is effectively denied to me. Think I'll send it back as I fear that it will also not play nicely with my Sky Q box
Graham
30 REPLIES 30
Message 2 of 31
Re: Brand new Smarthub 2 will not accept default password
factory reset hu by pressing recessed button on back and hold for 20/30 secs until lights flash then try correct password
Message 3 of 31
Make sure you are using the wireless password and not the Admin password.
Message 4 of 31
Definitely sing the correct password - but thanks.
Graham
Message 5 of 31
Graham
Message 6 of 31
Thanks I will give that a go and will report back. Meanwhile I've reverted to my old Home Hub which has never given me any problems.
Graham
Message 7 of 31
So the factory reset worked!   Brilliant - even the Sky Q box connected.  You can hear a 'but' here!  Wouldn't connect to my Alexa devices.  Said it couldn't connect to a public network....?
I shall start a new topic as this one is now fixed - very many thanks for the help
Graham
Message 8 of 31
the public/private network is set normally in windows nothing to do with hub
Message 9 of 31
It might be worth factory resetting your Alexa devices and try connecting them again to your Smarthub.
Message 10 of 31
I had a lot of faffing about getting the danged things to connect with my HH5 - I really don't want to go on a voyage of discovery again with Alexa. I'll see what comes up from my question, but thanks for the suggestion.  I'll keep it in mind.
Graham
