Message 11 of 17
Re: Broad band router and upgrade
Why are you so desperate to get a ew homehub? Is the one you have not working? A new hub won't do anything that your old hub isn't aready doing other than work on the 5GHz channel, if your devices can use it. Remember that the range of the 5GHz id shorter than the 2.4GHz that your present hub works on.
Message 12 of 17
well got  like for like hub and still getting drops on pc and wi fi on phone bt b/b to ask why but not getting straight answer
Message 13 of 17
it does not always mean a hub problem to have a disconnection problem
Message 14 of 17
ll tell what could be the reason as  have a open reach box whichonly has the connection to the router nothing else and today I had cut of even with 3 lights showing blue
As aw advised to attache a ADSl filter to the connection when i do I get no conniection
Message 15 of 17
you do not need a filter on any socket if you have infinity as you already have a filtered face plate fitted also do any of the Openreach modem change colour when the hub changes colour
Message 16 of 17
well i am not that rich to afford Innfinty b/band thus have the socket only and that only has the adsl wire plugged in it thus still have cut of on wireles and on desk top
Message 17 of 17
Ok personally i would stay with the hub you already have as changing it will not really improve any thing
