gregldn
Message 1 of 14
BroadBand speed dramatically slows down after few minutes
Hi all,
My broadband speed drastically slows after few minutes. I have to switch off/on the BT hub and got 5 minutes of ok internet speed but it becomes a nightmare again after few minutes (it takes 5-10 minutes to open gmail....)
I changhed the filter, the phone socket to a new one, ect...
Any ideas?
Cheers
Greg
13 REPLIES 13
raymie67
Expert
Message 2 of 14
Re: BroadBand speed dramatically slows down after few minutes
You probbaly need to post the adsl stats from your router and also the results of a BT speed test to get any help.
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
gregldn
Message 3 of 14
Where do I find ADSL stats?
This is speed from today:
Time / Download Speed / Updload speed, you can see that download speed decreases with time.
Today 15:14197 kbps (24.6kB/s)605 kbps (75.6kB/s)
Today 15:03431 kbps (53.9kB/s)603 kbps (75.4kB/s)
Today 14:40852 kbps (107kB/s)605 kbps (75.6kB/s)
Today 14:291015 kbps (127kB/s)
606 kbps (75.8kB/s)
Tags (1)
Message 4 of 14
 can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) http://speedtester.bt.com and post the results .
Someone may then be able to offer help/assistance/suggestions to your problem
gregldn
Message 5 of 14
Thanks, is this what you are looking for?
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days,
07:46:46
Downstream:6.367 Mbps
Upstream:747.8
Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex
A
Latency type:Fast
Noise margin
(Down/Up):
4.6 dB / 5.5
dB
Line attenuation
(Down/Up):
28.9 dB / 21.3
dB
Output power
(Down/Up):
20.7 dBm / 12.6
dBm
FEC Events
(Down/Up):
0 / 0
CRC Events
(Down/Up):
1438602 / 256
Loss of Framing
(Local/Remote):
0 / 0
Loss of Signal
(Local/Remote):
0 / 0
Loss of Power
(Local/Remote):
0 / 0
HEC Events
(Down/Up):
1645469 / 124
Error Seconds
(Local/Remote):
28000 / 143
Message 6 of 14
have you had an email recently from BT advising your exchnage was being upgraded?
are you connected to the master or the test socket or somewhere else?  do you have other extension sockets in other rooms in your home?
gregldn
Message 7 of 14
For information, I just moved to new house and I am first time user of BT broadband.
I am going to check the socket but in the meantime, here are the results from the speedtest:
Download speedachieved during the test was - 326
Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional
Information:
Your DSL Connection Rate :6519 Kbps(DOWN-STREAM),
747 Kbps(UP-STREAM)
IP Profile for your line is - 5751 Kbps
gregldn
Message 8 of 14
Cant make test Tap3 because, can not follow instructions with Windows 7
Message 9 of 14
forget test 3
if home is a new build do you have this on an outside wall external_NTE_1.png  if so that is your new master and cannot be touched
Message 10 of 14
if this is a new contract with Bt then you need to complain as your conenction is now on 21cn adsl2+ and with your attenuation your connection should be about 16mb not the 6mb currently
http://www.kitz.co.uk/adsl/max_speed_calc.php
in addition your throughput/download is rubbish and you need to email the mods to get it fixed.  they may hopefully get you on to adsl2+ at the same time  http://bt.custhelp.com/app/contact_email/c/4951
