Message 11 of 22
Re: Broadband Capped?
Hi John46
They dont have a BT master socket just an alumiium
faceplate that was in the house when they moved in.
I will try and get my stepgrandson to redo hub test and get
the rest of the info and a BT Speedtest also.
Thanks.
Message 12 of 22
are there other sockets in other rooms?  is the one you are conencted to the first socket in your home where the BT wires enter from outside?
Message 13 of 22
Yes the metal plate is the main incomer for BT but there are
3 extension sockets routed round the outside of the house
but I dont know who installed them.
Norm.
Message 14 of 22
it may help your connection if you could check to see if the bellwire is conencted to terminal 3 and if so remove it from master and allextension sockets as it is known to cause noise problems on your line  see here
bellwire removal
Message 15 of 22
Hi ImJolly
I took the metal plate off last year when I was housesitting and the bellwire is connected,
so I did my own fix I bought some doublers and removed the relevant connecting wires
I also repeated this round the house so each box had the bellwires removed,the
speed went from a constant 1.2mb/1.7mb to 3.5mb/4.4mb.
Norm.
Message 16 of 22
hi it would help if you could post the full hub stats showing all the errors you need to click on the show more detail tab on the hub stats page
Message 17 of 22
Message 18 of 22
Hi this is a full printout of original image,
I am still trying to get step grandson to do Bt speedtester
output image but irs always manana with him.
Message 19 of 22
hi once you can maintain 3days + stable connection we can the give you a link to the forum mods who can reset the noise margin which will then improve your connection speed with your attenuation you should be connecting at around 7.9mb
Message 20 of 22
Hi Guys
Sorry for the long delay,my step grandson
was suppose to email the hub readout on Friday
when i spoke to him he said he had to reset the hub again,
I said this is ridiculous as it needs 3 days + to get up to speed.
Anyway long story short his mother is going to get Infinty
installed so I guess all this will be moot.
Thanks for help and quick replies you are true stars.
You can close this thread off,thanks for the help
I may be back!!!
Normksi9
