cmcheung93
Message 1 of 32
Broadband Connection - Cannot load webpages
Hi
My broadband light on the home hub is steady blue, and my laptop can search for and connect to the broadband via both wireless and ethernet cable. However, when I open the browser the page is blank and loads for about 10-20 minutes before saying 'the webpage is not available'. I've tried resetting the home hub as instructed by BT advisors but it only worked the first time and then failed again. I have had no success talking to technical team as they just keep repeating the same thing and redirecting my calls. I was wondering if anyone could help?
31 REPLIES 31
Message 2 of 32
Re: Broadband Connection - Cannot load webpages
have you tried a different web browser
cmcheung93
Message 3 of 32
Yes I've tried on both IE and Google Chrome
Message 4 of 32
can you post the adsl stats from your router and run btspeedtester and post the results not beta version
cmcheung93
Message 5 of 32
How do I bring up the ADSL stats?
Message 6 of 32
Ok Work through tis information and post bak your hub stats and results of the speed test
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
also post your full hub stats details shown in this link http://www.btinternet.com/~cbeddoe/others/adslstats.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 7 of 32
if you are using a hub enter 192.168.1.254 into your browser, enter password then navigate to adsl stats
cmcheung93
Message 8 of 32
ADSL
Connection Information
Line state:Connected
Connection time:0 days, 00:08:43
Downstream:3.125 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):4.4 dB / 21.0 dB
Line attenuation (Down/Up):56.7 dB / 31.5 dB
Output power (Down/Up):19.3 dBm / 12.4 dBm
FEC Events (Down/Up):47387285 / 6947
CRC Events (Down/Up):115780 / 6615
Download speed 1.51
Upload speed 0.31
Ping latency 153.25
Message 9 of 32
can you try the quiet line test as per john46 post please
Message 10 of 32
could you please try and run the full bt speed test as we need to see your IP profile
