cmcheung93
Message 11 of 32
Re: Broadband Connection - Cannot load webpages
I have tried the quiet line test - it is normal and I can't hear anything.
Will do the full speed test now.
Message 12 of 32
are you connected to the test or master socket as described in john46 post?
you have a very large number of errors for only 8min connected - have you been having problems with your connection dropping or have you been resetting trying to improve your connection?
cmcheung93
Message 13 of 32
Currently I'm not connected because I would not be able to access the Internet and thus this forum.
I cannot run the speed test because it says I don't have Java but I have installed Java but it still doesn't show up.
I have resetted the home hub several times to try and get the broadband to work.
Message 14 of 32
there is something causing a lot of noise hence why connecting to the test socket should help
do you have other sockets in your home apart from the master socket?  if so have you removed the bellwire from terminal 3 in the master and all the extensions
bellwire removal
cmcheung93
Message 15 of 32
I'm not connected to the master socket
I spoke with a BT advisor and she said that some of my packages have been lost and they have to change the domain?
Message 16 of 32
that was why I suggested you connect to the test socket assuming you have an NTE5 master like this  master socket nte5.jpg  the test socket is behind the bottom half
cmcheung93
Message 17 of 32
Yes I have that - but I don't have any screwdrivers to open it?
Message 18 of 32
that is a problemSmiley Sad
cmcheung93
Message 19 of 32
Do you think I should just wait until the people at the exchange change the domain? Would that solve the problem?
Message 20 of 32
I don't think that will solve the noise problem.  do you have telephone extension sockets in other rooms whether in use or not?
