cmcheung93
Message 21 of 32
Re: Broadband Connection - Cannot load webpages
Yes I do. They now said that there is no fault with my line and they have to send an engineer to see what the problem is and they want to charge me 99 pounds for that?
Message 22 of 32
I would borrow a screwdriver first
Message 23 of 32
so would i the test socket is the first thing to try
cmcheung93
Message 24 of 32
I found a screwdriver! What am I meant to do now with the test socket?
Message 25 of 32
if you have front plate off then connect a filter then connect router to filter.  can you then post new adsl stats please
cmcheung93
Message 26 of 32
Hello
I have now plugged the filter and router into the test socket and the Internet works fine. Here are the ADSL stats and speed test results.
ADSL Line Status
Connection Information
Line state:
Connected
Connection time:
0 days, 00:03:00
Downstream:
2.813 Mbps
Upstream:
448 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
Unknown or no mode configured
Latency type:
Interleaved
Noise margin (Down/Up):
9.0 dB / 21.0 dB
Line attenuation (Down/Up):
56.4 dB / 31.5 dB
Output power (Down/Up):
19.1 dBm / 12.4 dBm
FEC Events (Down/Up):
43 / 0
CRC Events (Down/Up):
1 / 0
Download speedachieved during the test was - 2.37 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :2.98 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2.5 Mbps
My query now is why does it not work on my other phoneline socket?
Thanks a lot for your help!!
Message 27 of 32
that's a lot better
there is obviously a problem with your internal wiring - have you removed the bellwire from all your sockets as it is known cause of interference
cmcheung93
Message 28 of 32
Hi
I removed the bell wire from Terminals 3 and 4 (Orange and White), but still can't load webpages...this is what comes up:
This webpage is not available
The server at www.bbc.co.uk can't be found, because the DNS lookup failed. DNS is the web service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network. It can also be caused by an unresponsive DNS server or a firewall preventing Google Chrome from accessing the network.
cmcheung93
Message 29 of 32
Hello
IT'S WORKING!!!!!!!!
It's finally working - thank you soooooooooooooooo much for all your help. You made my day! Have a great night!! 😄
You're so much more helpful than the technical support team on the phone. 🙂
Message 30 of 32
Hi glad you have it working now 🙂 if you have any other problems anytime just post back and someone will help
