Message 41 of 57
Re: Broadband Connection Keeps Dropping - ERROR_NO_CARRIER
Thanks John46, the moderator has been in touch and asked for details of a speedtest which I have forwarded.
Message 42 of 57
great as the mods are involved they will get things sorted for you keep the post informed on progress please
Message 43 of 57
My IP profile is currently set at 6126Kbps and my DSL connection rate is 6944 Kbps. My last speedtest gave the download speed as 5616 Kbps. I've seen a ratio of 88.2% mentioned elsewhere in the forum. Is there an expected ratio of profile to connection?
Message 44 of 57
hi yes your IP profile is correctly matching your connection speed you are on the 88.2% profile system
Message 45 of 57
88.2% is the ratio or your profile to your connection speed - check yours
Message 46 of 57
Good news. An Openreach Engineer today (thanks to the moderator for arranging) and he discovered a fault at the exchange. The issue appears to have been a secon set of broadband wires connected to my line. These were disconnected and the line stats in terms of speed have increased to over 8Mbps from 7Mbps. The issue we've had was frequent disconnects, so will monitor for 24 hours before rejoicing!
Message 47 of 57
sounds good news keep us informed
Message 48 of 57
Line has now been up for more than 24hours, first time since 9th December following hardware fix at the exchange. Previously connection was dropping up to 15 times per day.
IP profile has gone up from around 6100Kbps to 7150Kbps
Connection Rate has gone up from around 7000Kbps to 8275Kbps
The Noise margain for Down seems to have gone down about 1.5dB to 7.9dB
For my Attenuation of 47.dB Klitz estimates
adsl2+ (21CN) 6400 kbps IP Profile 5500 kbps
But my profile is 7150Kbps... my line stats are as follows. Any idea why the IP profile is over 1Mbps higher than predicted?
HH3 Stats.
ADSL Line Status
Connection information
Line state:     Connected
Connection time:     1 day, 03:13:16
Downstream:     8,275 Kbps
Upstream:     888 Kbps
ADSL settings
VPI/VCI:     0/38
Type:     PPPoA
Modulation:     G.992.5 Annex A
Latency type:     Interleaved
Noise margin (Down/Up):     8.3 dB / 8.5 dB
Line attenuation (Down/Up):     47.5 dB / 23.8 dB
Output power (Down/Up):     0.0 dBm / 12.4 dBm
FEC Events (Down/Up):     551934 / 6192
CRC Events (Down/Up):     3153 / 29
Loss of Framing (Local/Remote):     0 / 0
Loss of Signal (Local/Remote):     0 / 0
Loss of Power (Local/Remote):     0 / 0
Loss of Link (Remote):     0
HEC Errors (Down/Up):     85472 / 31
Error Seconds (Local/Remote):     0 / 23
Message 49 of 57
hi can you please post the full results of the BT speedtest
speedtester.bt.com
Message 50 of 57
you look like you are on a very good line and will be getting a better speed then the Kitz prediction it could yet go higher when your noise margin reachs its default 6
