dg93
Newbie
Message 1 of 2
Broadband Device Utilisation
Hi is it possible to check the utilisation of my broadband against the client PC's & Laptops that are connected to the router?
I'm continually over the threashhold of the bandwith that I pay for as part of the package and I want to check if I have a specific PC that has issues or high utilisation.
Might consider recharging the kids for their use!!!!
Dave
1 REPLY 1
Guru
Message 2 of 2
Re: Broadband Device Utilisation
Not with a HomeHub 3.  It would probably need a pretty upmarket router to do so; might be cheaper to update the package!
You can put monitor software on PCs and some other devices; but that would have to be on a device by device basis.
One that should do the job is http://www.softperfect.com/products/networx/  I haven't used it so can't guarantee it will be easy to set up or even that it will do the job.  Other people may well have specific recommendations.
