john46
Message 11 of 32
Re: Broadband Download Speeds keep dropping off
monkeybill
Message 12 of 32
Shows an area close to me which relies on our exchange with a problem on the 28th but that was resolved same day.
monkeybill
Message 13 of 32
Sorry, this is a screen shot of the issue repoerted;
monkeybill
Message 14 of 32
Okay, so tested again and again same as last night.  This is much worse than I was getting with standard ADSL.  This has to be a capacity issue as a friend not too far away off the same exchange is having the same issues.
Come on BT this is not Fibre Broadband that I am paying for!
monkeybill
Message 15 of 32
Is there any way of contacting moderators as left for week to see if problem goes and it has actually got worse. Last night my download speed was 3Mb?
ray_dorset
Distinguished Guru
Message 16 of 32
Do you have a Homehub 5 ?
If not, I'll try again 🙂
monkeybill
Message 17 of 32
ray_dorset
Distinguished Guru
Message 18 of 32
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home or http://bthub.home
Please miss out any data you don't want to post
monkeybill
Message 19 of 32
Hi Thanks for your reply.  Helpdesk data screen shot attached.
ray_dorset
Distinguished Guru
Message 20 of 32
You're synced at max for Infinity 1 on the download, but I don't like the look of your upstream.
Does it bear any relation to the DSL checker estimate for your line? www.dslchecker.bt.com
