monkeybill
Message 1 of 32
Broadband Download Speeds keep dropping off
Hi
I have had a pretty good line in terms of stability bar a coupe of early issues but I am not getting really volatile speeds in the evening particularly (seems okay very early in the morning and up to around lunch time) but over last week or so, my download speeds have been really volatile and particularly slow compared with max speeds I have been getting.
See attached image which shows BT Speed Tester results.  Really not sure what to do next, can anyone help?  I have reset my BT Hub but makes no difference.
Thanks.
MB
31 REPLIES 31
imjolly
Message 2 of 32
Re: Broadband Download Speeds keep dropping off
Was there test done wired or wireless?
monkeybill
Message 3 of 32
Hi Wired direct to the Hub.
imjolly
Message 4 of 32
What exchnage are you on? Just there are problems with Lanark as can be seen with the forum posts
monkeybill
Message 5 of 32
We are on Darley Dale exchange.
Thanks for replies to post.
monkeybill
Message 6 of 32
Do moderator still pick up issues on the forums, be good to get their opinion as the BT Helpline has been anti help!?!
john46
Message 7 of 32
yes the mods are around but do not read every post
monkeybill
Message 8 of 32
Could my problem be a capacity issue at the exchange, seems to be evenings only as just retested,
john46
Message 9 of 32
what exchange are you on
monkeybill
Message 10 of 32
Darley Dale
