Newbie
Message 1 of 3
Broadband Dropping off continually (First Time ever)
Hi, this is the first time this has happened
Im on a Bt Infinity Package (for approx 18 months no problems)
Im running on WIFI
2 laptops on wifi
One Xbox 360
2 tablets
2 phones
Sky TV link
(Not all running at same time or sparingly used, no streaming except Xbox 360 for gameplay)
Has been crashing several times in last few days?
It seems to be a major issue when the Xbox now connects to Xbox Live online and their is an online game
Disconnected ADSL Router + Homehub and shut down all wifi linked items
Switched off for 5 minutes (as suggested by BT) reconnected ADSL Router/Homehub, then reconnected all devices
Crashed within 10 minutes and a few times more after this
Have done line test on 17070 #2 and the line is perfectly clear (telephone line)
Have done BT line test for fault - No fault
No apparent broadband faults in my area reported by BT
Have accessed homehub router page
Refreshed connection on Wifi
Disconnected, Reconnected Homehub
Just created a 5Ghz connection with new SSID to run alongside standard 2.4Ghz standard Wifi connection
swapped all devices becuase they claim connection is clearer and better for WIFI, except PC across to new connection, seems to work fine, but still experience crashes
Have reset Homehub and now post the following Event Log, so this is where I believe someone can help ID
the actual proplem (I hope)
Could someone with the right knowledge of the system please take a look at the event log and analyse the information
I see there are a number of errors and would like to know why these errors are occuring?
Can someone advise if this event log looks OK, or is there some issues that need addressing
16:30:39, 13 Nov.(16604.880000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9000, internal ports: 9000, internal client: 192.168.1.76
16:30:11, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.75:49935-​>157.56.124.87:443 on ppp1)
16:30:11, 13 Nov.BLOCKED 1 more packets (because of First packet is Invalid)
16:29:07, 13 Nov.IN: BLOCK [16] Remote administration (TCP 61.160.224.128:32833-​>86.134.175.111:80 on ppp1)
16:26:10, 13 Nov.IN: BLOCK [16] Remote administration (UDP 63.148.88.16:49555-​>86.134.175.111:161 on ppp1)
16:25:27, 13 Nov.(16293.690000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9000, internal ports: 9000, internal client: 192.168.1.76
16:24:03, 13 Nov.IN: BLOCK [16] Remote administration (TCP 222.161.197.148:40333-​>86.134.175.111:22 on ppp1)
16:21:48, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.75:49484-​>157.56.124.94:443 on ppp1)
16:21:46, 13 Nov.BLOCKED 1 more packets (because of First packet is Invalid)
16:21:44, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.75:49484-​>157.56.124.94:443 on ppp1)
16:20:47, 13 Nov.IN: BLOCK [16] Remote administration (TCP 123.196.116.66:18678-​>86.134.175.111:22 on ppp1)
16:20:15, 13 Nov.(15981.450000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9000, internal ports: 9000, internal client: 192.168.1.76
16:15:03, 13 Nov.(15669.510000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9000, internal ports: 9000, internal client: 192.168.1.76
16:13:18, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.75:50374-​>46.228.136.5:443 on ppp1)
16:13:18, 13 Nov.BLOCKED 1 more packets (because of First packet is Invalid)
16:13:18, 13 Nov.BLOCKED 3 more packets (because of First packet is Invalid)
16:13:16, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.75:50374-​>46.228.136.5:443 on ppp1)
16:11:18, 13 Nov.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:50811-​>204.154.111.224:80 on ppp1)
16:09:52, 13 Nov.(15357.910000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any-​>9000, internal ports: 9000, internal client: 192.168.1.76
16:08:50, 13 Nov.(15296.110000) Lease for IP 192.168.1.79 renewed by host Taras-​iPhone (MAC 5c:8d:4e:4b:45:6e). Lease duration: 1440 min
16:08:50, 13 Nov.(15296.110000) Device connected: Hostname: Taras-​iPhone IP: 192.168.1.79 MAC: 5c:8d:4e:4b:45:6e Lease time: 1440 min. Link rate: 72.2 Mbps
16:08:50, 13 Nov.(15296.040000) Lease requested
2 REPLIES 2
Message 2 of 3
Re: Broadband Dropping off continually (First Time ever)
You would be much better connecting the Xbox using an Ethernet cable, or broadband extenders. A wireless connection is going to give poor results, especially if you have other devices connecting.
Newbie
Message 3 of 3
Hi Keith
Thanks for the advice
The Xbox has been connected on the WIFI since the BT Infinty upgrade without any previous issues
so its been fine for atleast 18 mths, although yes it would perform better I know.
I will check your help pages,
thanks
But im still curious as to why im getting "invalid" and "blocked" errors in the event logs
so any advice or interpretation from an Engineer or BT "Techie" would be most helpful
