sarahavincent07
Message 11 of 46
Re: Broadband Infinity speed problems
I just did a speed test on betaspeed.test and the results are:
Ping 8
Down 22.45
Up 4.56.
However if I do an upload and check it is:
`ping 74
down 6.83
up 0.84
sarahavincent07
Message 12 of 46
Ping 8
Down 22.45
Up 4.56.
ping 74
down 6.83
up 0.84
sarahavincent07
Message 13 of 46
The think one came up with the same results, just cant work out how to link it to this site!!
sarahavincent07
Message 14 of 46
sarahavincent07
Message 15 of 46
Does that work????
XRaySpeX
Recognised Expert
Message 16 of 46
Yes, that's good. Nice & flat :).
The speedtests are all consistent with your connection speeds. The issue is why is your connection speed so much slower than BT's estimates. For that we need to see the BT Broadband Availability Checker table.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
sarahavincent07
Message 17 of 46
sarahavincent07
Message 18 of 46
This is the result if I try to upload a picture!!
XRaySpeX
Recognised Expert
Message 19 of 46
See Uploading Images
sarahavincent07
Message 20 of 46
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange CHELMSFORD is served by Cabinet 12
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateWBC FTTC 18x2 Provide AvailabilityWBC FTTC 18x2 Sim AvailabilityLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date       ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date     Left in JumperOther Offerings     Availability Date       Premise environmentStatus
VDSL Range A (Clean)4432.47.95.327.6AvailableAvailable--Yes--
VDSL Range B (Impacted)36.621.27.23.716.5AvailableAvailable--Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 7--5 to 12.5Available--------
WBC ADSL 2+ Annex MUp to 7Up to 15 to 12.5Available--------
ADSL MaxUp to 2.5--2 to 5.5Available--------
WBC Fixed Rate2 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRI--
NTEFaceplate--
Last Test Date18-01-1970
