imjolly
Message 31 of 46
Re: Broadband Infinity speed problems
If using test socket with filter then post stats from your router and see if any changes
sarahavincent07
Message 32 of 46
I just did!!
sarahavincent07
Message 33 of 46
Posted at 9:41
sarahavincent07
Message 34 of 46
It was 1.3!!
imjolly
Message 35 of 46
That's not hub stats. Same as message 6
sarahavincent07
Message 36 of 46
Ah, ok, doing now.
sarahavincent07
Message 37 of 46
Product name:
BT Hub 6A
Serial number:
+084316+NQ64288611
Firmware version:
SG4B1000B316
Firmware updated:
06-Dec-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 4 Minutes 9 Seconds
Data rate:
5.81 Mbps / 24.65 Mbps
Maximum data rate:
5807 / 25695
Noise margin:
6.2 dB / 6.3 dB
Line attenuation:
23 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
16386 MB Uploaded / 20493 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-R5PM
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-R5PM
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:84:C9:B8:CC:69
Software variant:
Boot loader:
7.33.1
Keith_Beddoe
Message 38 of 46
@sarahavincent07
As you are not getting the contracted speed, you are entitled to a free visit from Openreach, to sort the problem out.
Do you want to take advantage of this?
See Complaints about slow broadband speed
Its probably an issue with your internal phone wiring. Do you have any extension sockets, as its possible that they are not wired to the correct point?
sarahavincent07
Message 39 of 46
I'm not getting the speed and only one person can use the internet at a time! Which is a nightmare when you have 2 kids wanting to play on line.
Open reach have visited, they said it was my hub. BT sent out a new hub no difference.
sarahavincent07
Message 40 of 46
No internal wiring. Hub is plug straight into the socket as it comes in from wall. I have tried 2 ethernet cables to rule out that. Wireless is exactly the same.
