mutzig23
Message 1 of 8
Broadband Infinity
Just upgraded broadband fron Infinity 1 38MB to Infinity 2 80MB. Absolute rubbish and a waste of money.#It seems that if you use a wireless connection you will never increase the download speed no matter what the speed from the exchange is.
On 38MB on a wireless system I was getting 36-37 mb on Infinity 2 80mb i am getting 35-38mb. What is the point in upgrading if you cant get Improved wireless speeds.  Total ripoff.
Spoke to BT technical, they are not Interested in helping, just go through the company speel and do not offer any help at all
7 REPLIES 7
licquorice
Message 2 of 8
Re: Broadband Infinity
You will if your wireless link is capable of higher speeds. You will only achieve the speed of the slowest link in the chain.
No ISP will guarantee or assist with wireless speeds, there are just too many variables beyond their control.
Have you split the 2.Ghz and 5 Ghz wireless SSIDs to see if that helps?
brianhes
Message 3 of 8
Have you done any tests with a wired ethernet connection, as the wireless connection could be limiting the speed?
imjolly
Message 4 of 8
did your conenction actually increase to 80mb?  it is not automatic just because you are on infinity 1 max
mutzig23
Message 5 of 8
I get 80mb when connected by wire but only 35mb on wireless. When I contacted BT they said this is normal and every broadband supplier has the same situation. I contacted Virgin, Sky anf Talk Talk who confirmed they have alower speed on wireless but by only 10-15%. BT speed is 56%lower.
Waste of time
mutzig23
Message 6 of 8
BT sent confirmation e mail stating the lowest speed I would get is 65mb. there was no qualification that this is only on a wired system.
Yes I split 2,4GHz and 5.0 GHZ. when on 5.0GHZ the speed actually got worse
gg30340
Message 7 of 8
Likewise there was no qualification that you would get full speed over a wireless connection. BT and all ISPs only guarantee speeds over a wired connection to the router at your house.
There are far to many variables for any ISP to guarantee your wireless connection speeds. Things like the construction of your house, other wireless sources and electrical interference can all affect your wireless speeds.
It can also be affected by what type of wireless network card is installed on your computer and if the drivers for the card are up to date.  Have you checked for updated drivers. Use the card manufacturer's website rather than Windows because they can often be out of date.
pippincp
Sage
Message 8 of 8
It sounds as if your wireless card is only "wireless g" you need "wireless N" for faster speeds.
