Anonymous
Not applicable
Message 1 of 5
Broadband Latency Type
My Latency Type is Interleaved. However, I would like it to be switched to Fast. Could a moderator do this for me (I've had this done in the past)?
1. Product name: BT Home Hub
2. Serial number: +068343+NQ41323929
3. Firmware version: Software version 4.7.5.1.83.8.261 (Type A) Last updated 11/09/18
4. Board version: BT Hub 5A
5. DSL uptime: 5 days, 13:27:42
6. Data rate: 1078 / 19334
7. Maximum data rate: 21468 / 19948
8. Noise margin: 5.9 / 4.2
9. Line attenuation: 4.3 / 11.1
10. Signal attenuation: 4.3 / 10.1
11. Data sent/received: 13.0 GB / 258.2 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4 GHz Wireless network/SSID: HUB
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: HUB5
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 34:8a:ae:da:87:9c
24. VPI/VCI: 0 / 38
25. Modulation: G.992.5 Annex A
26. Latency type: Interleaved
27. Software variant: AA
28. Boot loader: 1.0.0
4 REPLIES 4
imjolly
Message 2 of 5
Re: Broadband Latency Type
Connection looks good with 5 days stable so have asked mods to help. They will post here tomorrow
RobbieMac
Moderator
Moderator
Message 3 of 5
Hi @Anonymous,
Thanks for your post and welcome back!
The stability of your connection looks good so we can help move you over to fast path from here.  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
PaddyB
Moderator
Moderator
Message 4 of 5
Hi @Anonymous,
Thank you for sending in your details. I've place a request to have interleaving turned off. This normally take around 48 hours to complete, as long as the connection remains stable.
I'll follow up with you on Wednesday to see how the connection is performing.
PaddyB
PaddyB
Moderator
Moderator
Message 5 of 5
Hi @Anonymous,
I've tested your connection and your interleaving is showing as off (Fast). As long as the connection remains stable it should stay like that.
If there is any instability, the DLM will react and reapply interleaving if needed.
PaddyB
