Message 1 of 7
Broadband Speed Issue Help
Over the last week my Broadband speed has dropped from its normal 6-8mb down to approximately 1mb. Router was restarted approx 2 days ago as per the usual suggestion. I do realise that it takes up to 10 days to resynch so will keep on checking over the next few days. There have been no changes to my wiring or connection and I connect directly to the socket.
I have attached the speedtester results below.
 Download speedachieved
during the test was - 1.37 Mbps
For your connection, the acceptable
range of speeds is 0.4 Mbps-2
Mbps
Additional Information:
Your DSL Connection Rate
:8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for
your line is - 1.5 Mbps
Router Stats:
ADSL line status
        Connection information
Line stateConnected
Connection time1 day, 23:23:44
Downstream8,128 Kbps
Upstream448 Kbps
        ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)12.8 dB / 26.0 dB
Line attenuation (Down/Up)6.0 dB / 6.0 dB
Output power (Down/Up)9.8 dBm / 12.3 dBm
Loss of Framing (Local)25
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)129 / 0
CRC Errors (Down/Up)38 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)18
6 REPLIES 6
Message 2 of 7
Re: Broadband Speed Issue Help
Something must have interrupted the line a few times, you will just have to leave it connected for about five days and see if the IP profile increases again.
Message 3 of 7
Hi once you have maintained a 3/5 day stable connection with NO Hub Restarts your IP Profile will the rise automatically every restart will start the time scale again
Hub restarts are the worse thing you can do
Message 4 of 7
Thank you both. Will post a reply in a couple of days. I am aware that restarting is not normally a good thing but why is it always the first suggestion BT make for any issues?
Message 5 of 7
it is a basic check that in most cases can clear a connection problem however an IP profiler problem like yours needst a stable connection to increase
Message 6 of 7
Thank you both for your response and help much appreciated. My broadband speed has normalised to approx full speed. I was unable to select you both as answer given so had to do a coin toss as a fair way to do it.
You two are both doing a fantastic job on these forums!
Message 7 of 7
Glad to help any time 😉
