reme8488
Message 11 of 14
Re: Broadband Speed and Connection Problem
@Jezza wrote:
Hi
results from the BTlineTest
 Download speedachieved during the test was - 109 Kbps
 For your connection, the acceptable range of speeds is 50-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :3584 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
No idea why it says "135 kbps" as im obviously getting nothing near that.
One example is "counter-strike" online multiplayer game, when i load it, my Latency is at a normal 40-50.. then it shoots up to 5-600, making it unplayable.
Maybe its the exchange i dunno, might just sort it-self out in the next couple days, but its been 3 days now so im a bit concerned.
The 135 Kbps is your IP (speed) profile, which is there due to your line not holding a stable connection (your modem must have resynced a few times at least and induced a rock bottom speed profile).
Normally it takes 3 - 5 days of having a stable connection for a profile to move upwards.  As you've been connected for 3 days you should see an improvement in a day or two Jezza.
Kind regards... Tom
BT Infinity2:
Jezza
Message 12 of 14
Thanks lets hope so
I'll keep you posted
Jezza
Message 13 of 14
Thanks for help
Sorted now. 4 days later, but seems ok now. 🙂
reme8488
Message 14 of 14
@Jezza wrote:
Thanks for help
Great stuff Jezza.  Hopefully that will be you sorted now mate.  Smiley Happy
Kind regards... Tom
BT Infinity2:
