muldy29
Message 11 of 16
Re: Broadband Speed dropped from 2.7Mbps to 448KBps Today 06/06/12
Now getting a speed test result of 3.24Mbps, so think BT were mucking about with something yesterday
imjolly
Message 12 of 16
that's good just keep checking and if it goes low again then come back
muldy29
Message 13 of 16
This is from just now, SNR has dropped from the 18db i was getting, hopefully it will go a bit lower soon
DSL Details
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 3040 kbs 448 kbs
Max Rate: 2116 kbs 848 kbs
Noise Margin: 5.0 dB 19.0 dB
Attenuation: 58.8 dB 31.5 dB
Output Power: 17.7 dBm 11.9 dBm
Protocol: G.DMT Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {3840} Vendor: {ALCB} Specific: {0 }
ATM PVC: 0/38
Rate Cap: 2116 kbs
Attenuation @ 300kHz: 58.8 dB
Uncanceled Echo: -21.4 dB Ok
VCXO Frequency Offset: 13.0 ppm Ok
Final Receive Gain: 34.5 dB Ok
Excessive Impulse Noise: 0 Ok
Traffic Statistics
IP Traffic Bytes Packets Errors %
Transmit: 301959800 43 0 0
Receive: 1079024362 7863748 0 0
ATM Traffic Cells Errors %
Transmit: 13629459 0 0
Receive: 207265149 0 0
DSL Link Errors
Collected for 10Days1:14:31
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 22521 11 2 0:08:20
Loss of cell Delineation 8340 2 0 0:19:22
DSL
Link Retrains: 4 0 0 9Days16:41:10
DSL Training Errors: 2 0 0 10Days1:06:28
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 3 0 0 10Days0:46:57
Loss of Signal Failures: 3 0 0 10Days0:46:57
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 3 0 0 10Days0:46:57
**bleep**. Seconds w/Errors: 4590 14 3 0:06:40
**bleep**. Sec. w/Severe Errors: 366 0 0 4:19:46
Corrected Blocks: 7431195 204958 47459 0:00:01
Uncorrectable Blocks: 24502 18 4 0:06:40
DSL Unavailable Seconds: 572 0 0 9Days16:40:44
john46
Message 14 of 16
6dB is the normal default you have a 3mb + connection which is about right for your attenuation
imjolly
Message 15 of 16
connection looking better and speed is really good for your attenuation
john46
Message 16 of 16
post back any time if you need help or advice someone will always be glad to help
