I have a HomeHub4 and use ethernet cable.
With HH2 I used to get 1Mbps but it dropped to about 130kp
bps. I got a fault rectified after a lot of complaining and with HH4 I got 2 to 5 Mbps. It is now back down to 130kbps with very occasional spurts to 500kbps..
If I login to a BT Wifi hotspot I can get 2 to 3Mbps.
Enter your phone number and post results remember delete number
can you post stats from hub.
information from the event log, such as the SNR Margin, shortly after a resync.
Troubleshooting >
Event Log >
Category 'WAN'
The 2 lines will show noise margin and connection speed and will be when hub last reset
DOWNLOAD 0.25 Mbps 0.20 0.13
UPLOAD 0.06 Mbps 0.02 0.01
Download Speed : 0.13 Mbps
Upload Speed : 0.01 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
speedtest.btwholesale.com
00:22:26 17 Feb. WAN connection ATM connected
00:22:16 17 Feb. DSL Link Up: Down Rate=160Kbps Up Rate=424Kbps; SNR Margin Down=6.3dB Up=7.0dB
18:14:34 16 Feb. WAN connection ATM connected
18:14:27 16 Feb. DSL Link Up: Down Rate=288Kbps Up Rate=456Kbps; SNR Margin Down=6.6dB Up=8.5dB
17:54:47 15 Feb. WAN connection ATM connected
17:54:37 15 Feb. DSL Link Up: Down Rate=160Kbps Up Rate=280Kbps; SNR Margin Down=6.8dB Up=8.8dB
18:28:54 14 Feb. WAN connection ATM connected
18:28:47 14 Feb. DSL Link Up: Down Rate=160Kbps Up Rate=275Kbps; SNR Margin Down=6.4dB Up=7.9dB
17:04:32 13 Feb. WAN connection ATM connected
17:04:25 13 Feb. DSL Link Up: Down Rate=288Kbps Up Rate=443Kbps; SNR Margin Down=6.7dB Up=8.1dB
18:14:07 12 Feb. WAN connection ATM connected
18:14:00 12 Feb. DSL Link Up: Down Rate=160Kbps Up Rate=328Kbps; SNR Margin Down=6.7dB Up=7.6dB
can you try using the test socket with a filter and see if that helps stabilise your and also improve your conenction speed
did you try quiet line test by dialing 17070 option 2 and best with corded phone
as you say you have done everything that would normally be suggested here then you need to get another engineer visit
Hi @leafenw,
How are things with your connection. Did you manage to get another engineer out to take a look at your connection?
If you're still experiencing issues with your connection, please post back and I'll be happy to take a look at this for you.
PaddyB
