Message 1 of 11
Broadband Speed dropping again
I have a HomeHub4 and use ethernet cable.
With HH2 I used to get 1Mbps but it dropped to about 130kp
bps. I got a fault rectified after a lot of complaining and with HH4 I got 2 to 5 Mbps. It is now back down to 130kbps with very occasional spurts to 500kbps..
If I login to a BT Wifi hotspot I can get 2 to 3Mbps.
10 REPLIES 10
Message 2 of 11
Re: Broadband Speed dropping again
Enter your phone number and post results remember delete number
can you post stats from hub.
information from the event log, such as the SNR Margin, shortly after a resync.
Troubleshooting >
Event Log >
Category 'WAN'
The 2 lines will show noise margin and connection speed and will be when hub last reset
Message 3 of 11
DOWNLOAD       0.25 Mbps  0.20                0.13
UPLOAD                               0.06 Mbps 0.02 0.01
  1. Best Effort Test:
Download Speed : 0.13 Mbps
  1. Upstream Test:
Upload Speed : 0.01 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
  1. 22:00 16/02/18
speedtest.btwholesale.com
00:22:26               17 Feb. WAN connection ATM connected
00:22:16               17 Feb. DSL Link Up: Down Rate=160Kbps            Up Rate=424Kbps; SNR Margin Down=6.3dB       Up=7.0dB
18:14:34               16 Feb. WAN connection ATM connected
18:14:27               16 Feb. DSL Link Up: Down Rate=288Kbps            Up Rate=456Kbps; SNR Margin Down=6.6dB       Up=8.5dB
17:54:47               15 Feb. WAN connection ATM connected
17:54:37               15 Feb. DSL Link Up: Down Rate=160Kbps            Up Rate=280Kbps; SNR Margin Down=6.8dB       Up=8.8dB
18:28:54               14 Feb. WAN connection ATM connected
18:28:47               14 Feb. DSL Link Up: Down Rate=160Kbps            Up Rate=275Kbps; SNR Margin Down=6.4dB       Up=7.9dB
17:04:32               13 Feb. WAN connection ATM connected
17:04:25               13 Feb. DSL Link Up: Down Rate=288Kbps            Up Rate=443Kbps; SNR Margin Down=6.7dB       Up=8.1dB
18:14:07               12 Feb. WAN connection ATM connected
18:14:00               12 Feb. DSL Link Up: Down Rate=160Kbps            Up Rate=328Kbps; SNR Margin Down=6.7dB       Up=7.6dB
Message 4 of 11
can you try using the test socket with a filter and see if that helps stabilise your and also improve your conenction speed
Message 5 of 11
Did all that last August when problem first appeared and it made no difference.
Message 6 of 11
did you try quiet line test by dialing 17070 option 2 and best with corded phone
Message 7 of 11
Yes all that stuff
Message 8 of 11
as you say you have done everything that would normally be suggested here then you need to get another engineer visit
Moderator
Moderator
Message 9 of 11
Hi @leafenw,
How are things with your connection. Did you manage to get another engineer out to take a look at your connection?
If you're still experiencing issues with your connection, please post back and I'll be happy to take a look at this for you.
PaddyB
Message 10 of 11
I am not forking out £180 for an engineer to come and tell me that there is a fault in the openworld box.
I have been sent an "accelerator" plate to go on the wall. I will fit it, try if for a few days see what difference it makes.
I would be interested to read experiences of others who have tried this device
