Message 11 of 16
Re: Broadband and line 7days without
You need to try unclipping the front and connect phone to the test socket you can now see and check for dial tone
Message 12 of 16
Done that and no ring tone.  I guess the problem has to be the master socket box
Message 13 of 16
No, it proves the fault to outside of your house, as there is nothing at the test socket.
Does your line come in from a pole, or underground?
Message 14 of 16
The line comes in from a pole.
Message 15 of 16
Then is nothing you can do, apart from report a phone line fault, no dial tone, cannot make any calls. Do not report a broadband fault, as it will take longer to fix. Phone faults are fixed quicker, as you may need to make urgent calls.
Once the phone line is fixed, the broadband will come back.
Message 16 of 16
Thank you so much for your help. Very much appreciated to you all
John
