Newbie
Message 1 of 4
Broadband boost engineer
We moved to BT on 13/06/17 and since then we have only had speed between 0.60 Mbps and 2:00 Mbps. Open reach engineer has been out and did not find any fault in the line and advised me to contact BT and request a broadband engineer. I have since contacted BT and gone through tests and finally was able to book a broadband engineer who will visit in five days time. I am a bit concerned that BT advisor was unable to book an engineer unless I agree to pay £120 if the fault is found to be within the house or equipments. I don't know why I had to agree to this term when Openreach engineer has already been to the property and did not find any problem inside the property. I would not like to pay since the problem is BT's network related. Any advise will be appreciated.
thanks
3 REPLIES 3
Message 2 of 4
Re: Broadband boost engineer
You won't pay the fee if:
The fault is in BT’s network
If the fault is with your BT hub and it is in warranty (contract)
If the fault is with your BT TV box (in or out of warranty)
If you have the same fault within 28 days
In case of BT Infinity, if you call within 28 days after the install
In case of BT Infinity, if the Openreach Fibre modem needs replacing
They are registered as a Chronically Sick and Disabled Person
You will pay the fee if the fault's with:
Your home wiring past the main socket, for example, extensions
The way you've got your equipment connected
Interference from something, for example your phone, alarm system, micro-filter or broadband router
Damage to our network, for example cut wire, damage from building work, trees or pets, or damage to sockets
Message 3 of 4
the charge is purely an advisory the boost engineer is a specialist engineer who will check the line from your home back to the exchange to try and get you the best possible speed
Newbie
Message 4 of 4
Dear John4, Thanks for replying to my post. It makes things much clearer regarding charges. Engineer is due to visit on Wednesday. Looking forward to a usable internet connection!
