Newbie
Message 1 of 6
Broadband connection dropping when receiving inbound call
Hi,
When I receive an inbound phone call my broadband connection disconnects for a couple of minutes.
I have a dual plug master socket (One socket for telephone and one for broadband). I also have a pretty new HomeHub.
Does anyone have any ideas what is wrong ?
Thanks,
5 REPLIES 5
Recognised Expert
Message 2 of 6
Re: Broadband connection dropping when receiving inbound call
Some possible causes from here - http://www.kitz.co.uk/adsl/connectionprobs.htm
adsl drops out when phone call is made or received.
Incorrectly installed filters - check filters are installed correctly see here.
Faulty filters - replace one by one to identify which filter is faulty.
Fault on the line - unlikely but possible if all else has been eliminated.
Newbie
Message 3 of 6
Thanks,
As I have dual socket, I don't have a ADSL filter that I can swap out, as shown in the diagrams in your links. Therefore do I need to find a way to get a fault on the line checked ?
Recognised Expert
Message 4 of 6
It could be a faulty face plate but
If you post the stats from your router
For homehub - 192.168.1.254
Navigate to ADSL Settings or use the A-Z at the top right
Click on More Details and then post the results.
And post the results from http://speedtester.bt.com/
then someone may be able to help.
Newbie
Message 5 of 6
Hi, (BT speed tester was down, showed an error, hence the delay) here are the stats
ADSL line status
Line stateConnected
Connection time0 days, 16:13:48
Downstream2,080 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.3 dB / 18.0 dB
Line attenuation (Down/Up)54.0 dB / 31.0 dB
Output power (Down/Up)17.5 dBm / 11.9 dBm
Loss of Framing (Local)37
Loss of Signal (Local)6
Loss of Power (Local)0
FEC Errors (Down/Up)8149494 / 1
CRC Errors (Down/Up)301952 / 2147480000
HEC Errors (Down/Up)nil / 3
Error Seconds (Local)11
BT speed tester results
Download speed = 1261 kbps
DSL Connection Rate = 2080 Kbps down, 448 Up
IP Profile 1500Kbps
Regards,
Recognised Expert
Message 6 of 6
Did you try the quite line test 17070 option 2? Best done with a wired phone. Although given you noise margin I'd doubt there is much noise.
Can you try a different phone?
The fault will probably be one of Phone, Socket, Hub or line fault.
