Newbie
Message 1 of 3
Broadband connection drops from one of my PCs
Hello
My wifi works perfectly well on one laptop, and two mobile devices, but I've recently bought a new laptop and find that when I use it go online the connection will drop after a while, particularly if I try to download/upload anything. This will also cause the connection to drop for any other devices using the wifi at the same time, and they will only reconnect once I've reset the hub. The new laptop is a Samsung RV515. Is there any way to solve this problem?
2 REPLIES 2
Message 2 of 3
Re: Broadband connection drops from one of my PCs
hi read through this link it may help you
http://www.btinternet.com/~cbeddoe/wireless/hub3_wireless.html
Message 3 of 3
you could also try changing the router fromb/g/n to just b/g as older wifi is probably 'g' whereas new samsung is probably 'n'
