Newbie
Message 11 of 15
Re: Broadband connection keeps dropping
The wifi is now intermittant on channel 11
Message 12 of 15
you can try downloading inssider2 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
Message 13 of 15
Try a couple of other channels, working down from 11.
I do know that there are some issues with the WiFi performance of the home hub 3. How far away are the devices from the home hub, is the signal showing good or excellent?
Newbie
Message 14 of 15
I have put it onto channel 1 and every single wireless device just started working - yippee!!
Message 15 of 15
That is often the default for many routers, you are lucky if its a quiet channel Smiley Wink
See how it goes, I cannot guarantee it will fix it, but its usually worth a try. Also try to avoid using wireless devices at the extreme range of the signal, as that causes re-transmissions due to poor quality.
