fate_
Message 1 of 11
Broadband constantly disconnecting
For about 3 or 4 days now my broadband has been constantly disconnecting. It will just randomly disconnect for about a minute or so and then start again, although this isn't a long time it's really inconvenient and I'd like to see if I could find out why it's started doing it now when i've never suffered from these problems before.
The issue started on the day where there were heavy winds in my area so i'm not sure if that could have affected something, I'm not sure really what could of made it happen suddenly.
10 REPLIES 10
samjef11
Message 2 of 11
Re: Broadband constantly disconnecting
1 First of all have you powerded off you home hub for ten seconds and then powered it on again?
2 have you done a bt line fault test?
fate_
Message 3 of 11
bt line fault test? and yes i've reset the home hub
samjef11
Message 4 of 11
IF you could login into the bt home hub control panel at http://192.168.1.254/login.lp and click on
Advanced Settings and then click Continue to Advanced Settings click on Broadband and then click on adsl and copy all of the  ADSL line status and post it in your reply.
By the way do you know the admin password by default it should be on the back of your home hub and is you hub version 1.0 1.5 or 2.0?
fate_
Message 5 of 11
I'll do it tomorrow and post back what I find, thanks.
fate_
Message 6 of 11
Line state Connected
Connection time 0 days, 0:03:15
Downstream 8,128 Kbps
Upstream 448 Kbps
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 5.3 dB / 22.0 dB
Line attenuation (Down/Up) 33.0 dB / 17.5 dB
Output power (Down/Up) 19.8 dBm / 12.1 dBm
Line state ConnectedConnection time 0 days, 0:03:15Downstream 8,128 KbpsUpstream 448 KbpsVPI/VCI 0/38Type PPPoAModulation ITU-T G.992.1Latency type InterleavedNoise margin (Down/Up) 5.3 dB / 22.0 dBLine attenuation (Down/Up) 33.0 dB / 17.5 dBOutput power (Down/Up) 19.8 dBm / 12.1 dBm
Message 7 of 11
fate_ could you please repost the hub figures again this time could you post the full details on that page by clicking on the tab at the bottom of the figures you have just posted that will give us more details of your connectiion
fate_
Message 8 of 11
Connection time 0 days, 0:13:57
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 5.4 dB / 22.0 dB
Loss of Framing (Local) 0
Loss of Signal (Local) 3
Loss of Power (Local) 0
FEC Errors (Down/Up) 619 / 0
CRC Errors (Down/Up) 1 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 2
Message 9 of 11
ok could you please try the bt quiet line check using a corded phone connected to the master socket dial 17070 option 2 there should be no noise if there is report the fault on 151 as a noisy line but do not mention broadband if there is any problem with this test then once it is fixed your broadband will stabilize its connection soon after
fate_
Message 10 of 11
There was no noise
