ciel
Message 1 of 8
Broadband constantly dropping out despite reporting faults 4 times
So i'm pretty much at the end of my tether now.  Moved house at the beginning of May (to a totally new area) and should be getting speeds of around 7, since the move have had nothing but problems with wired and wireless broadband connections.  Have rung and reported faults 4 times to be told each time that they can see that the broadband is dropping but there is no fault on the line therefore nothing to be done.  I am reasonably tech savvy so have done the basic checks - changed channels, changed sockets, changed cables, etc, etc, but still getting the same problems.  Have limited the amount of devices connected and thats not helped either.  Set up in the house is exactly the same as previous house if not better.
Am amazed that BT admit broadband is dropping but tell me there is nothing to be done.  Am very frustrated and would appreciate any advice or suggestions.....
7 REPLIES 7
imjolly
Message 2 of 8
Re: Broadband constantly dropping out despite reporting faults 4 times
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).  must be done wired
enter your phone number and post results  remember to delete nimber  https://www.btwholesale.com/includes/adsl/main.html
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
ciel
Message 3 of 8
Thanks for the response.  Am unable to complete the diagnostic as my speed is now less than 1mb.  Working fine on wireless so have ordered a new cable just in case thats the problem.....
BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)63.949.317.111.3--Available----
VDSL Range B (Impacted)4828.612.76.4--Available----
ADSL MaxUp to 8--7 to 8Available----
Fixed Rate2----Available----
VDSL Multicast------Available----
imjolly
Message 4 of 8
Can you post the adsl stats from your router
ciel
Message 5 of 8
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 17:12:26
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):15.5 dB / 26.0 dB
Line attenuation (Down/Up):12.4 dB / 6.0 dB
Output power (Down/Up):19.9 dBm / 12.1 dBm
FEC Events (Down/Up):7683 / 0
CRC Events (Down/Up):32 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):51 / 0
Error Seconds (Local/Remote):28 / 0
imjolly
Message 6 of 8
you have the max connection speed for adslmax and your exchange unfortunately is not capable of adsl2 so unless you upgrade to fibre connection you have as fast as you can get
can you run btspeedtester diagnostic test and post results
ciel
Message 7 of 8
Not able to get fibre where we are at the moment. And I still cant get an answer from BT as to why it keeps dropping. Still cant run the bt speed tester on a wired connection as speed is less than 1mb
imjolly
Message 8 of 8
even with download speed of <1mb btspeedtester should work
the dslchecker results you posted if done with phone number show you can order fibre with a connecton estimated speed 63/49mb
you could try phoning options team to see if you can upgrade and what deal they will offer you - best is infinity 1 based on estimated speed
