Cogsly
Message 1 of 15
Broadband drop out when it rains every time
Ok so ive had constant issues with this issue since October and much worse since January.
Everytime it rains the internet drops out. I dont even have to look out the window anymore for a weather update.
Ive contacted BT several times who tell me theres no fault at all on the line even though my router just cycles through all the 3 colours (HH6). My line coming in must be 30 years old and is twisted pair. Bt installed the new split main box when we had broadband here. Only 1 phone connected and phone line crackles lightly when router goes off.
Now after yet another heated exchange im told an engineer will come out and check for 130quid. I say its an intermittant fault. They dont quite grasp this.
Now here comes the funny part.....
If i connect my old HH3 it connects ok. Still drops out once it rains but reconnects ok. If i plug my HH6 in after my HH3 connects then the HH6 connects ok again...right up until it rains.
If i simply leave the HH6 on after a disconnect it endlesly power cycles.
Why would the HH3 connect ok then HH6 be ok after this?
Why does mt broadband drop out when it rains.
Why would the line test be ok even though HH6 say its not fonnecting when the HH3 can.
Bt niw sending out another (the 3rd) HH6 out. This wont change anything.
Im on option 2....i pay a fair whack every month to use a fast connection. Can someone please shed some light on this?
Thx in advance.
14 REPLIES 14
john46
Message 2 of 15
Re: Broadband drop out when it rains every time
the charge is an advisory providing the fault is at the test socket there is no charge for the visit the line noise is the cause of your disconnections and needs reporting as a noisy line on 151 with no mention of broadband in the call
there are many posts about the hub 6and its assorted problems just stick with the hub 3
Keith_Beddoe
Message 3 of 15
Welcome to this customer to customer forum. @Cogsly
See http://bt.custhelp.com/app/answers/detail/a_id/12439/c/
That explains possible charges.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
If there is, report it as a phone fault not a broadband one.
Just do not mention about the broadband, otherwise it will end up in the wrong queue, and you will wait forever.
As the fault will be external, there would be no charge.
Cogsly
Message 4 of 15
But how come the broadband team and the call team say theres no issue from their end. The noise is only light and only there when it rains
Keith_Beddoe
Message 5 of 15
They will not see it as the line tester is not that accurate.
There is probably a corroded jont somewhere, so it just needs Openrech to check and remake ant external connections.
Is you phone line fed from a pole?
Cogsly
Message 6 of 15
Yes. Cable 30 years plus old. Dont fancy risking 130 quid charge so mass arguing trying desperatly to get something actusky resembling customer service.
Like i said if they come out and its dry what do i do?
Its beyond stupid
Keith_Beddoe
Message 7 of 15
Its beyond stupid
Read the link I gave you, there is no visit charge unless its your wiring, or your equipment.
There is no upfront charge for a visit, or if no fault is found. That is unlikely as there must be an exposed external joint which should be obvious.
Cogsly
Message 8 of 15
Ok bud thx
Cogsly
Message 9 of 15
Is there a better hub thats up to date has good wifi coverage and is just 1 box not 2 like HH3?
Happy to pay just want this nightmare over
john46
Message 10 of 15
As you have a hub 6 that latest one available you mention 2 boxes not sure what you mean
