dwcshoot
Message 1 of 12
Broadband dropouts
For a few months now our BT Homehub5 has been regularly dropping out giving the orange light. This mostly happens at night where it can turn blue for a short period before starting the cycle all over again. I have been working late shifts and when I get in just after midnight it is usually doing this. During the day this very rarely happens. When it is working the speed seems good. I did a quiet line test and all seems fine. I don't normally have a phone plugged in. I have had the cable from the homehub to the tv disconnected for a while so nothing else is physically connected to the hub. I did notice that the hub has had an update in mid July. Is it a coincidence my problems have started around this time? Prior to this it was rare to have any problems.
11 REPLIES 11
dgw1
Message 2 of 12
Re: Broadband dropouts
Have you tried using a different phone cable going into the router, and checked any extension wiring coming out of your main phone socket going to the router? It might also be worth replacing the filter box and doing a factory reset on your router...
DavidM
Moderator
Moderator
Message 3 of 12
Hi @dwcshoot and welcome.
I'm sorry you're having problems with the connection. Have you noticed if anything else happens at the same time like street lights or heating pumps switching on? I think it might be worht checking for REIN issues. Take a look at kitz REIN for details.
Cheers
David
dwcshoot
Message 4 of 12
Here is a sample of my dropouts. At very similar times, every day, for the last couple of months the same has happened.
02:50:53, 23 Sep.(11461.290000) The system is going DOWN for reboot.
02:50:53, 23 Sep.(11461.290000) OpenRG is going for reboot by IPC command
02:50:48, 23 Sep.(11456.290000) OpenRG will go down for reboot in 5 seconds
00:43:31, 23 Sep.( 3818.560000) SD-​100 (1)
23:39:17, 22 Sep.( 9455.240000) The system is going DOWN for reboot.
23:39:17, 22 Sep.( 9455.240000) OpenRG is going for reboot by IPC command
23:39:12, 22 Sep.( 9450.240000) OpenRG will go down for reboot in 5 seconds
21:01:12, 22 Sep.(73713.180000) The system is going DOWN for reboot.
21:01:12, 22 Sep.(73713.180000) OpenRG is going for reboot by IPC command
21:01:07, 22 Sep.(73708.180000) OpenRG will go down for reboot in 5 seconds
00:32:09, 22 Sep.( 7619.760000) The system is going DOWN for reboot.
00:32:09, 22 Sep.( 7619.760000) OpenRG is going for reboot by IPC command
00:32:04, 22 Sep.( 7614.760000) OpenRG will go down for reboot in 5 seconds
22:25:51, 21 Sep.STP Alert: Port eth0 leaving blocking state.
22:24:40, 21 Sep.( 4492.230000) The system is going DOWN for reboot.
22:24:40, 21 Sep.( 4492.230000) OpenRG is going for reboot by IPC command
22:24:35, 21 Sep.( 4487.230000) OpenRG will go down for reboot in 5 seconds
21:09:12, 21 Sep.( 6613.780000) The system is going DOWN for reboot.
21:09:12, 21 Sep.( 6613.780000) OpenRG is going for reboot by IPC command
21:09:07, 21 Sep.( 6608.780000) OpenRG will go down for reboot in 5 seconds
19:18:23, 21 Sep.(61130.750000) The system is going DOWN for reboot.
19:18:23, 21 Sep.(61130.750000) OpenRG is going for reboot by IPC command
19:18:18, 21 Sep.(61125.750000) OpenRG will go down for reboot in 5 seconds
02:19:00, 21 Sep.(20464.940000) The system is going DOWN for reboot.
02:19:00, 21 Sep.(20464.940000) OpenRG is going for reboot by IPC command
02:18:55, 21 Sep.(20459.940000) OpenRG will go down for reboot in 5 seconds
20:37:23, 20 Sep.( 6091.690000) The system is going DOWN for reboot.
20:37:23, 20 Sep.( 6091.690000) OpenRG is going for reboot by IPC command
20:37:17, 20 Sep.( 6085.840000) OpenRG will go down for reboot in 5 seconds
18:56:35, 20 Sep.STP Alert: Port eth0 leaving blocking state.
18:55:21, 20 Sep.(137773.180000) The system is going DOWN for reboot.
18:55:21, 20 Sep.(137773.180000) OpenRG is going for reboot by IPC command
18:55:16, 20 Sep.(137768.180000) OpenRG will go down for reboot in 5 seconds
04:40:25, 20 Sep.(86476.460000) SD-​100 (1)
dwcshoot
Message 5 of 12
@DavidM thanks for your response. I can't think of anything that switches on or off at those times or regularity. I have electric heating which occasionally triggers the doorbell to go off but that is onny twice a day!
dwcshoot
Message 6 of 12
Here is my router info
1. Product name:BT Home Hub
2. Serial number:+068343+NQ41953309
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 18/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 11:39:17
6. Data rate:4239 / 33852
7. Maximum data rate:4536 / 36585
8. Noise margin:5.9 / 3.7
9. Line attenuation:47.2 / 25.3
10. Signal attenuation:32.5 / 21.3
11. Data sent/received:119.3 MB / 1.2 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-RZ5W
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-RZ5W
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:xx
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
DavidM
Moderator
Moderator
Message 7 of 12
Thanks for confirming that @dwcshoot.
I'll be happy to take a look at this for you. Can you please drop me over an email with the details? You'll get the contact the moderators link in my profile.
Cheers
David
dwcshoot
Message 8 of 12
Thank you @DavidM . What details would you like sent?
Dave
DavidM
Moderator
Moderator
Message 9 of 12
Just complete and submit the webform in my profile and we'll look into it @dwcshoot.
Cheers
David
dwcshoot
Message 10 of 12
Just after the HH5 rebooted once again I checked the stats. Before I could post them up here it did yet another reboot seconds after.
5. DSL uptime:0 days, 00:03:48
6. Data rate:4193 / 33794
7. Maximum data rate:4491 / 36028
8. Noise margin:6.0 / 3.4
9. Line attenuation:32.8 / 25.3
10. Signal attenuation:32.6 / 21.2
11. Data sent/received:150.2 MB / 1.4 GB
13. BT Wi-fi:Yes
23. MAC Address:
