Message 1 of 12
Broadband dropping and phone calls interrupting connection
I am aware that these technical issues may have been covered in other posts, but as a new member I wanted to ensure my problem wasn’t lost.  Apologies if this is incorrect etiquette.
For the past few weeks, my Home Hub 2 has been dropping its connection.  As a result, the speed is now a quarter of what it was (I understand this is "training" and/or DLM).  I have carried out a few experiments and found that calling the phone number always now drops the broadband.  I have tried removing the two phones, to the extent that all I have connected is the Hub. Even then dialling the number from my mobile causes connection to be lost.  I have tried 3 or 4 different microfilters without success.
I have a very old style socket, with no removable faceplate or test socket behind, so I don’t know what else to try.
Any ideas gratefully received.
Many thanks
David
11 REPLIES 11
Message 2 of 12
Re: Broadband dropping and phone calls interrupting connection
You need an Openreach engineer visit as it sound you have a High resistance joint which is causing your disconnections
Message 3 of 12
Many thanks for your prompt response.
I did try a live chat with BT support and they also suggested an eningeer visit, but at £99 basic.  Is that right?
Message 4 of 12
there is only a charge if the fault is found with your internal wiring or equipment after the master socket
Message 5 of 12
You probably cannot answer this question, but would yoiu have an idea what is more likely with such a problem?
Does the fact that my wiring is obviously very old make a difference?
If I decided to go with Infinity would all the wiring be upgraded inclusive of that installtion so that I avoid repair costs if applicable?
Many thanks
Message 6 of 12
Hi the only change that is made if you move to infinity is the face plate of the master socket
the fault is most likely a faulty joint somewhere between your home and the exchange
Message 7 of 12
OK.  I will probably arrange an engineer's visit and hope they don't keep missing the appointments as they did the last time I called them out.
Many thanks for your help
Message 8 of 12
Pleased to help any time post back with how you get on as it can help others
Message 9 of 12
Just to update you.  I carried out some more tests.
I had an old BT Hub 1.0 and connected that and got the same problems, ruling out a fault with the existing Hub.
I then moved a wireless keyboard and mouse extender away from the hub and for a moment thought that was working.  But it didn't last long!
I then connected by ethernet and again had false success.  Calling my number doesn't seem to cut the connection that often, but I have had a couple of random drops whilst composing this post.
Does this help or cloud the issue?  Is it more likely to be a wireless issue?  Should I stick with ethernet for the time being?
I will hold off calling the engineer until I see how it performs.
Thanks again.
Message 10 of 12
Unfortunately, after a few days, I've still suffered disconnects both when the phone rings and randomly.  Just now it cut out suddenly with the result that my profile's speed has been halved again.
I got no noise on the quiet line test the other day, but there does seem to a be little there now. I guess I need an engineer visit, but would appreciate confirmation.  My stats are as follows:
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:08:39
Downstream1,871 Kbps
Upstream779 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.3
Latency typeInterleaved
Noise margin (Down/Up)26.6 dB / 7.5 dB
Line attenuation (Down/Up)20.0 dB / 11.7 dB
Output power (Down/Up)0.0 dBm / 10.3 dBm
Loss of Framing (Local)207
Loss of Signal (Local)30
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)437
Many thanks
