Message 1 of 2
Broadband dropping but blue light.
Hi all,
my devices are losing connection 6/7 times a day. Both wired & wireless. Not all at the same time, it appears to be one device at a time, randomly.
the hub lights stay blue. Have changed the router.
BT can find no faults on the line. Any ideas what it could be?
edit to add: fttp, smart hub 2
1 REPLY 1
Message 2 of 2
Re: Broadband dropping but blue light.
have you turned of smart setup
Turn Off smart setup
for the wifi have you tried using a wfi analyser and see what channels in use by neighbours then try and select a free or less congested channel.. if you have SKY Q I would select another 5ghz channel and not use 36
