keredwh
Message 1 of 2
Broadband dropping out
This is a recuring problem. Every couple of months, my broadband will just drop out at random. It will work fine for weeks and then just start doing it again at random! Sometimes it will work fine all day other times (like today) it will drop out half a dozen times. Phoned BT, done all the usual checks over and over again but it's still happening!!
Can anyone tell from the details below what is going on??
Thanks.
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 00:15:45
Downstream4,542 Kbps
Upstream770 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)16.4 dB / 9.3 dB
Line attenuation (Down/Up)35.8 dB / 16.8 dB
Output power (Down/Up)15.3 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)3 / 174683
CRC Errors (Down/Up)1 / 195060
HEC Errors (Down/Up)0 / 0
Error Seconds (Local/Remote)1 / 10900
1 REPLY 1
Robinson71
Message 2 of 2
Re: Broadband dropping out
A similar problem to me...... posted above.
