I have Fibre 1 Broadband and a BT Hub 5. Recently the broadband has been dropping quite often. Also slow sometimes. Also when I first had the router the Wifi signal extended out into my garden but it no longer does.
Any suggestions as to what I can do about this? I'll probably call BT about it tomorrow, but wanted to know about options first. (EG new router, a Wifi booster or what?)
Thanks.
Hi @BelindaP,
Welcome back to the Community and thanks for taking the time to post.
Sorry to hear that you're having problems with your connection.
It's possible that your hub has gone fault but it's worth doing a few checks before you call in.
Do you have your hub connected to your master socket and have you noticed the hub lights changing colour or flashing?
Would you be able to post your hub stats and do the Silent line test?
Let me know how you get on 🙂
Matt
Hi Matt, in answer to your questions:
I don’t know where my master socket is I’m afraid.
Often I don’t see the lights on the router as it’s been in a room upstairs, but a day or two ago I brought here and it dropped a few minutes ago (21:51/21:52) – catch up TV stopped working and the router lights were flashing yellow or orange I think.
I did the quiet line test and this was fine.
Then I tried to get the stats you asked for. I tried to follow these instructions:
If using a BT Home Hub 4 or 5 navigate to 'Troubleshooting' then to 'Logs'. You will then find two lines which will state 'DSL noise margin' and 'DSL line rate', copy this info and include this in your post.
But these instructions don’t match what I have. I click Troubleshooting and see “Event Logs” not “Logs”, clicking on this shows me lots of options but NOT: 'DSL noise margin' and 'DSL line rate'.
Just in case this is useful here’s a copy of some of the info found in the “Helpdesk” page:
Firmware version: Software version 4.7.5.1.83.8.264 (Type A) Last updated 06/03/19
Board version: BT Hub 5A
DSL uptime: 0 days, 00:23:04
Data rate: 19999 / 70251
Maximum data rate: 20111 / 74931
Noise margin: 6.4 / 3.5
Line attenuation: 20.7 / 16.4
Signal attenuation: 20.3 / 16.7
Data sent/received: 874.4 MB / 8.6 GB
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Yes
2.4 GHz Wireless network/SSID:
2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
2.4 GHz Wireless security: WPA2
2.4 GHz Wireless channel: Automatic (Smart Wireless)
5 GHz Wireless network/SSID:
5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
5 GHz Wireless security: WPA2
5 GHz Wireless channel: Automatic (Smart Wireless)
Firewall: Default
MAC Address:
Modulation: G.993.2 Annex B
Software variant: AA
Boot loader: 1.0.0
Is this enough info for you? Let me know if you'd like any info from the Event Log. I’d be grateful for your thoughts, thanks.
Thank you @BelindaP,
Can you follow our Troubleshoot BT phone and broadband faults and see if it helps you?
If you still have issues, please reply to my private message.
DanielS
From the stats you posted previously you had a 70mb connection speed
check for line noise. Dial 17970 option 2 should be silent and best done with corded phone
An update to this: I called BT, they said there was a fault on the line. (NB I reported a fault about 6 times in the last few weeks by going online but at first was told yes there's a fault and now it's been fixed and after that each time was told there was no fault). So they sent an engineer out, he worked on the line at the green box and said he'd found and fixed a fault. Also he came and fitted an Open Reach Master Socket in my house. And finally BT have sent me a Smart Hub (I had a BT Hub 5 before). The Wifi signal for this hub seems MUCH better than the old hub as now I can get Wifi coverage at the end of my garden. (When I first had the Hub 5 it worked at the end of the garden but that no longer worked this year).
