Message 1 of 5
Broadband extenders for tv box
One of my broadband extenders has a flashing power light and will not reset - is there any way of forcing it? I've tried switching off and on and pressing the 'link' button as per the instructions.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Broadband extenders for tv box
Try a factory reset on both units. Post back with the make and model if you don't know how
Message 3 of 5
Thanks for your reply.
I only know what BT instructions say - press the 'Link' button for 15 seconds.  The units are 'Broadband extender Flex 500'.
I'd be delighted to try anything you can suggest.
Regards
Andy
Anonymous
Not applicable
Message 4 of 5
That's all there is to do if it's the extender that you have, the WiFi hotspot has a pinhole in the side that you press for one second.
If you've done a reset on both units and it's still failing then it sounds like you have a faulty one.
Just make sure that neither is plugged into an extension socket, particularly one with a surge suppressor
Message 5 of 5
Thanks.  They are definitely broadband extenders , have concluded that one is faulty, replacement on the way.
