hesuruio
Message 1 of 6
Broadband fault
Hello,
I have recently started a contract with BT and was told on Wednesday 19th of March that my broadband was ready to go.
I arrived from work happy to plug in my new BT Hub 4 and get connected after 2 weeks of waiting.
To my dissapointment nothing seem to work.
The hub goes through the same cycle everytime green->blue->orange with flashing red b underneath
I tried it iin every socket around the house including the main bt socket and including the test socket.
I tried 2 adsl filters with the same result.
If anyone is able to shed some light I would apreciate any sort of help I can get.
Thank you!
5 REPLIES 5
gg30340
Message 2 of 6
Re: Broadband fault
You need to contact BT and report that your broadband has not gone live. Call 0800 111 4567
hesuruio
Message 3 of 6
Re: Broadband fault
Well they keep telling me that an enngineer did some work at the exchange on the 19th of March and that the broadband connection should be active...
gg30340
Message 4 of 6
Re: Broadband fault
You need to keep telling them that it's not and that you want it sorted.
PaddyB
Moderator
Moderator
Message 5 of 6
Re: Broadband fault
Hi Hesuruio,
I'll be able to help you with your Broadband. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
hesuruio
Message 6 of 6
Re: Broadband fault
Hi PaddyB
I completed the Contact Us form.
This is my reference number: *********
Thanks! Tell me if you need me to do anything else.
