MK9999
Message 31 of 38
Re: Broadband is essentially unusable
OK, found this in the hub manager>settings>ADSL page. Does this shed any light?
imjolly
Message 32 of 38
You are in the bottom banded profile due to all the disconnections and or resets. If you could maintain a stable connection then banding will release with noise margin reducing in stages down to 6db with speed increasing at each stage
MK9999
Message 33 of 38
I've reset the hub to default tonight. No other resets (eg by the button) were done tonight, or last night. If it's getting reset multiple times, it's not by direct action.
licquorice
Message 34 of 38
Is your phone line noisy? Try a quiet line test on 17070
MK9999
Message 35 of 38
It doesn't seem noisy, not in a laymen's sense. I'll try a test.
licquorice
Message 36 of 38
It should be completely silent in between the announcements.
MK9999
Message 37 of 38
OK, done the quiet line test, used the test socket and diconnected everything except the phone. Listened for a while (quiet line test message was repeated 4-5 times). There is a barely discernable backround hum, and an occasional very faint click. There doesn't seem to be a discernable pattern to the clicks (time between clicks seems random).
licquorice
Message 38 of 38
It sounds like you have a line fault which is causing your broadband to disconnect which is in turn causing DLM to take action and slow down your connection. Report the fault as a noisy line rather than a broadband fault. Once the fault is cleared your speed will improve.
