john46
Message 11 of 14
Re: Broadband issue any help/advice please
Totally incorrect if the hub is faulty you will NOT be charged for a replacement
BrightStarFOX
Message 12 of 14
I never said if it was faulty. I said if it wasn't faulty
Keith_Beddoe
Message 13 of 14
Its worth checking the assembly of the plug front onto the power supply base. This is supposed to click into place, but if it has not fully located, it may be causing an intermittent connection.
They do need a lot of force, to click into place.
john46
Message 14 of 14
they will not send out a new hub unless it is first proved as faulty
have you tried a factory reset of the hub by using a pin in the restart hole at the back of the hub holding the pin in for at least 20 seconds
