raistuk
Message 1 of 6
Broadband issue/downstream speed.
Hi there
I've been using BT broadband for a few months now. I am on the unlimited package (i.e. up to 20mb download speed). When I first got this package my speeds were pretty erratic, usually starting off at around 3mb download and rising up to about 10-13mb ish following a couple of router resets / restarts. However more recently (i.e. the last week or so) the broadband download speed has decided to stay put at between 2-3 mb.
Here is an example of my speedtest history:
IP_ADDRESSTEST_DATETIME_ZONEDOWNLOAD_MEGABITSUPLOAD_MEGABITSLATENCY_MSSERVER_NAMEDISTANCE_MILES
86.174.41.12411/16/2011 9:44 PMGMT13.140.4735Newbury50
86.174.41.12411/16/2011 9:45 PMGMT13.150.4835Newbury50
86.174.41.12411/16/2011 9:47 PMGMT13.180.4239Newbury50
86.174.41.12411/16/2011 10:04 PMGMT10.590.3662London50
86.145.139.1141/18/2012 9:50 AMGMT2.020.29167London0
86.168.193.321/18/2012 10:08 AMGMT3.190.2341London50
86.168.193.321/18/2012 10:08 AMGMT3.190.2441London50
86.168.193.321/18/2012 10:15 AMGMT3.190.2435London50
86.168.194.2161/18/2012 10:27 AMGMT2.870.4235London0
86.180.164.1061/19/2012 10:52 AMGMT130.4331London0
86.180.164.1061/19/2012 10:53 AMGMT13.010.4731London0
86.180.164.1061/19/2012 11:13 AMGMT13.010.4731London0
86.180.164.1061/19/2012 8:01 PMGMT130.4131London0
86.164.159.981/20/2012 11:04 AMGMT12.990.3825London0
109.157.11.254########GMT0.750.17474Newcastle upon Tyne250
86.145.146.145########GMT0.480.12558Maidenhead50
86.145.146.145########GMT1.080.16534Maidenhead50
86.174.44.10########GMT2.90.3132London0
86.183.7.213########GMT13.150.4286Newcastle upon Tyne250
86.183.7.213########GMT12.560.432London50
86.163.83.120########GMT1.820.3925London50
86.174.44.29########GMT2.640.4725London0
86.145.137.80########GMT1.860.4733London0
86.148.110.13########GMT1.850.2335London0
86.161.158.28########GMT2.050.1645London50
86.147.233.17########GMT2.040.1547London0
86.166.34.69########GMT1.80.3135London50
86.163.229.40########GMT2.090.4327London50
86.163.229.40########GMT2.090.4425London50
86.163.229.40########GMT2.090.4331London50
86.163.229.40########GMT2.090.4132London50
86.163.229.40########GMT2.090.4227London50
86.147.234.123########GMT2.640.4220London50
86.166.64.105########GMT2.640.9415London50
I have tried multiple router restarts and resets and this has done nothing to improve things by any significant margin. In fact from reading around it I now realise I may have caused more damage by doing this as I have likely raised my SN margin by a significant amount which is now hovering around 30db for my downstream:
DSL Connection
Link Information
Uptime:0 days, 0:41:32
Modulation:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:1,199 / 3,071
Data Transferred (Sent/Received) [MB/MB]:8.45 / 28.70
Output Power (Up/Down) [dBm]:11.5 / 0.0
Line Attenuation (Up/Down) [dB]:10.0 / 25.0
SN Margin (Up/Down) [dB]:6.0 / 30.5
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):0 / 0
HEC Errors (Up/Down):0 / 0
Line Profile:Fast
Do I now have to wait for my SN margin to take 2 weeks to reset? Or is there anything I can do to fix this at my end (already having made sure the router is plugged into primary phone socket, moved away from electrical equipment etc).
I know my line is capable of over 10mb as it has been at that speed before, and realise that "up to 20mb" does not mean I will get 20mb... due to distance from exchange, etc.  However I feel that close to a 90% discrepancy is a bit much...
Any help or advice would be very much appreciated!
5 REPLIES 5
Message 2 of 6
Re: Broadband issue/downstream speed.
hi can you please post the connection time and connection speed from your hub as they are missing from your post and also a full BT speed test http://speedtester.bt.com/
Message 3 of 6
You should be getting 24 mb with your attenuation figures.
Because of your constant disconnections and restarts, your noise margin has risen to 30db and you have been put in a low banded profile.
If you leave it totally alone for 3-5 days, the speed should improve, step by step.
You must leave it powered on and no manual resets.
raistuk
Message 4 of 6
Thanks for the info Keith thats great to know, i'll leave it alone and let it sort itself out. Cheers.
Message 5 of 6
Keith the attenuation is 25 (opposite way to normal) so I would expect about 18mb not 24mb - still really good though
Message 6 of 6
How odd, I did not see that, thanks Smiley Wink
