Jimrob84
Message 1 of 24
Broadband issues
Hi
Since December 1st I’ve been having problems with my Broadband. It’s affecting or has affected all of my devices at one time or another:
  • For a week I was receiving DNS error messages on various web browsers (chrome, fire fox, and internet explorer) and being timed out. Switching to google dns did nothing to improve the situation. This was also the case for my phone.
  • Sky+ HD box struggles to load the on demand menu pages. Occasionally the pages load in full at the first time of asking, other times the pages either completely fail to load or the pages load without some of the images. Interestingly downloading content (films, tv) does not appear to be a problem.
  • PS4 times out when trying to sign in to the PSN. Sometimes I can connect but an attempt to perform a simple connection test ends in failure. I’ve also found it nigh on impossible to use the PS4’s streaming apps.
Contacted BT to report the issue and they performed various speed and line tests and concluded that everything, at least from there end, was fine. They did however arrange for an engineer to make some checks at the exchange and to perform some checks on the wiring in the house. He found no problems. He did however switch my HH3 for a HH5 which at the very least seems to have slightly improved web browsing. Sadly this has done nothing to improve performance on either the sky box or PS4. The same problems that have plagued me for a week are still persisting.
I’ve noticed from looking around on the forums that many people, particularly those on the infinity board, are suffering from similar problems.  Am I correct in assuming that this problem is with BT?
23 REPLIES 23
imjolly
Message 2 of 24
Re: Broadband issues
there are many posts recently about slow loading web pages and looks like it is a BT DNS problem although some have changed to google DNS with mixed results
Jimrob84
Message 3 of 24
Appreciate the response.
Yeah, I switched to Google DNS last week after the problems began on my computer, but it didn’t improve things. I did the same on PS4 and again there were no improvements.
I’ve just had a look at the hub event logs after trying to access the Sky on demand menus on my box. No idea what this all means, I’m not massively tech savvy I’m afraid:
It seems similar to other people's logs that I’ve seen on these boards over the past few days.
This is all pretty frustrating. Is BT working on a solution for all of this?
imjolly
Message 4 of 24
are you connectig to sky box wireless or wired
Jimrob84
Message 5 of 24
It's a wireless connection to the sky box and a wired connection to the PS4.
imjolly
Message 6 of 24
have you tried using ethernet for sky connection maybe via powerline adapters?
Jimrob84
Message 7 of 24
It doesn't seem to matter if I'm connecting wirelessly or wired.
The BT engineer did a four minute stress test on my internet connection and found no faults. So from what I can gather the problem appears to be at BT's end not mine.
john46
Message 8 of 24
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Jimrob84
Message 9 of 24
I'm not using HH4.
BT engineer switched my HH3 for a HH5 yesterday.
john46
Message 10 of 24
same applies for the hub 5
