Message 111 of 131
Re: Broadband keeps dropping Help please :)
i would agree as the hub is working
Miamii101
Message 112 of 131
Well they said its either down to the hub or the wiring in my last email.
Internet seems to be ok atmo
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 4:08:30
Downstream8,558 Kbps
Upstream1,169 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)11.4 dB / 5.9 dB
Line attenuation (Down/Up)35.0 dB / 18.1 dB
Output power (Down/Up)0.0 dBm / 13.1 dBm
Loss of Framing (Local)92
Loss of Signal (Local)12
Loss of Power (Local)0
FEC Errors (Down/Up)291539287 / 4294967232
CRC Errors (Down/Up)264 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)335
Message 113 of 131
if connection stays stable as it is then unlikely you will get another router.  noise margin is still high but at least it is stable
Message 114 of 131
just keep used posted
Miamii101
Message 115 of 131
Hey guys well il hopefully here back from the mod on monday heres my adsl settings for the weekend so far i mean its looking alright *touch wood*
ADSL line status
Line stateConnected
Connection time2 days, 7:26:27
Upstream1,169 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)10.9 dB / 5.7 dB
FEC Errors (Down/Up)577890740 / 4294967232
CRC Errors (Down/Up)368 / N/A
Error Seconds (Local)410
Message 116 of 131
if connection continues to stay stable then mods can see it and then get noise margin reset to 6db which will give a speed increase
Miamii101
Message 117 of 131
il leave it another 24-30 hours and we shall see hopefully it will 🙂 but we shall seeeee
Message 118 of 131
the mods will certainly reset the margin and then your speed increase will improve you should get around 11.7mb connection speed
Miamii101
Message 119 of 131
Well it got to 3 days i think maybe fell just shy it was in like at 9:55 ish so i think it may of got there 😛 but once again the drop casued a increase in speed look
ADSL line status
Line stateConnected
Connection time0 days, 0:33:33
Downstream9,687 Kbps
Upstream1,164 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)9.4 dB / 6.2 dB
Line attenuation (Down/Up)35.5 dB / 18.0 dB
Output power (Down/Up)0.0 dBm / 12.8 dBm
Loss of Framing (Local)104
Loss of Signal (Local)13
FEC Errors (Down/Up)7638542 / 0
CRC Errors (Down/Up)8 / N/A
Error Seconds (Local)448
Message 120 of 131
looks like your noise margin is dropping slowly with a corresponding increase in speed - and being done automatically as line appears stable
