logan
Message 1 of 21
Broadband keeps dropping and ip profile of 0.75Mbps.
Over the last few days our broadband has started to drop out and then come back. Occasionally the broadband light on the hub goes out completely. This has now given us an ip profile of 0.75Mbps, we normally get around 3-4Mbps.
I have done a noise test using the test socket on the master socket and it was quiet. Out of curiosity I also did it with everything plugged in and on and again no noise. I've also changed both the filters for the phone and the hub.
I have done a couple of manual restarted but have stopped doing that now. This is the connection info after the last drop out.
Anything else I can try?
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:00:43
Downstream:1,440 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 18.0 dB
Line attenuation (Down/Up):51.0 dB / 29.0 dB
Output power (Down/Up):17.3 dBm / 12.0 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):0 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):0 / 0
Error Seconds (Local/Remote):0 / 0
20 REPLIES 20
ghostzz
Message 2 of 21
Re: Broadband keeps dropping and ip profile of 0.75Mbps.
i would call customer care it sounds like a problem outisde of your home
Message 3 of 21
can you please post your hub stats again while it connected to test socket so to eliminate any internal wiring issues
logan
Message 4 of 21
I would rather not call customer care, last time I did that it took several calls and long waits to get anywhere other than them telling me to restart the router. Which eventually took an engineer to turn up and solve the problem within a few minutes at the exchange.
I shall connect the hh to the test socket and get back with the stats the first chance I get, might take a couple of days being the time of the year!
Message 5 of 21
No problem post back when you can if the community members cannot resolve the issue or it needs an Openreach we can put you ion touch with the forum moderators who are UK based BT specialists and who will take. Ownership of the case
logan
Message 6 of 21
I have yet to put the hh on the test socket, but what I have noticed is that occasionally the broadband will drop and the light on the hub will go out completely and won't come back on. However if I then get a dial tone on the phone the broadband will come back on.
Could this point to anything?
Message 7 of 21
Which version of the home hub do you have?
logan
Message 8 of 21
I have the home hub 3 type B.
Message 9 of 21
Ok thanks post back the hub stats when you can
Message 10 of 21
Thanks, it was just that when you said that the light went out, I thought that it might be a home hub 2.
