logan
Message 11 of 21
Re: Broadband keeps dropping and ip profile of 0.75Mbps.
These are the current stats where the router normally is today for comparision. I will go put it on the test socket and post those stats shortly.
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:01:57
Downstream:1,248 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):4.9 dB / 18.0 dB
Line attenuation (Down/Up):51.0 dB / 29.5 dB
Output power (Down/Up):16.6 dBm / 12.1 dBm
FEC Events (Down/Up):0 / 24
CRC Events (Down/Up):755 / 48
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):3645 / 40
Error Seconds (Local/Remote):0 / 0
logan
Message 12 of 21
These are the stats on the test socket.
ADSL Line Status
Connection time:0 day, 00:05:31
Downstream:1,312 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):5.9 dB / 18.0 dB
Line attenuation (Down/Up):51.0 dB / 29.0 dB
Output power (Down/Up):17.0 dBm / 12.1 dBm
FEC Events (Down/Up):0 / 12
CRC Events (Down/Up):169 / 21
HEC Errors (Down/Up):1406 / 16
Message 13 of 21
There is an increase in speed and noise margin, which would indicate that your extension wiring is affecting the speed and available bandwidth.
An increase in noise margin means that there is potential for a further increase in speed, if left in the test socket.
logan
Message 14 of 21
The first stats I posted on the first page have a higher noise and speed that the stats from the test socket, does this not imply that the wiring within the house is not the problem?
I have also just done another quiet line test through the test socket it and it is very crackly. It is raining now, the first quiet line test I did it was dry.
Thinking about it now the weather does seem to have a large effect on how the telephone line is and if the broadband stays connected or not.
Another set of stats with the hh moved back.
ADSL Line Status
Connection time:0 day, 00:04:53
Downstream:1,152 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Line attenuation (Down/Up):51.5 dB / 29.5 dB
Output power (Down/Up):16.9 dBm / 12.1 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):3 / 0
HEC Errors (Down/Up):3 / 0
Message 15 of 21
I agree, there are some inconsistant results. I would expect a connection of about 4384Kbs, based on your line length, so its probably worth asking the BT Care Team to arrange for a visit from a Broadband Boost Technician, to see if any fault can be identified.
If you would like to contact one of the UK based BT Care Team who moderate this forum, they should be able to arrange this.
They can be contacted using this link BT Care Team
They normally respond by phone or e-mail, within three working days, however you should get an immediate confirmation, with a tracking number.
logan
Message 16 of 21
The broadband has dropped twice again today with the broadband light on the hub going out completely. Each time I have had to just get a dial tone on the phone again and it connects back up.
I will get in contact with the care team.
Message 17 of 21
Please keep us posted on how you progress as it always helps others
logan
Message 18 of 21
I will do.
I just can't understand why I need to get get a dial tone on the phone to get the router to connect backup to the exchange when it drops. It seems to be happening much more ferquently now. Every few minutes.
The line to our house does run through trees, I wouldn't be surprised if they have caused a fault along the line letting water in. Whether that could cause the problems.
Message 19 of 21
A high resistance connection will cause exactly those symptoms. Picking up the phone tends to break down the HR, but only on a temporary basis.
logan
Message 20 of 21
I am fairly sure we have pinpointed the problem. This is a part of the line running upto our house.
Quite possible to see it is in a bad way, there are lots of nicks and broken bits in the insulation.
Our phone is now unusable now aswell due to so much noise. Broadband is just about hanging in there but slow and still dropping out.
Who can I call to report this and get sorted as quick as possible?
