Message 1 of 3
Broadband line reset chat assistant tell me lies
I spoke to two chat assistants Abhishek and SANDEEP, both were not very helpful.Both of them said my broadaband line was reseted 5 days ago.If this was true then my homehub would be automatically reseted and the adsl line status page would reset the connection time.This did not happen.
When i spoke to karen a week before christmas, she reseted my broadband line and my homehub was automatically reseted too.
My current max speed is now at 11..51mbps.I can get 13.50mbps if my downstream is above 15,000Kbps.That why i want a line reset.
My BT faceplate has two sockets,one for telephone and the other for broadband.No need for external broadband filters as it built in the faceplate.Homehub is placed next to the main bt socket.
ADSL line status
Connection Information
Line state Connected
Connection time 18 days, 01:42:53
Downstream 14,220 Kbps
Upstream 1,123 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Modulation G.992.5 Annex A
Latency type Fast
Noise margin (Down/Up) 7.9 dB / 5.9 dB
Line attenuation (Down/Up) 27.6 dB / 14.1 dB
Output power (Down/Up) 23.8 dBm / 1.7 dBm
Loss of Framing (Local/Remote) 0 / 0
Loss of Signal (Local/Remote) 0 / 0
Loss of Power (Local/Remote) 0 / 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 45146 / 0
HEC Errors (Down/Up) 305946 / 0
Error Seconds (Local/Remote) 23063 / 0
2 REPLIES 2
Message 2 of 3
Re: Broadband line reset chat assistant tell me lies
you have a 14mb connection speed and as on adsl2+ your profile will be 88.2% of connection speed
you have a stable connection from your stats but noise margin slightly higher than normal.  try conracting te mods and get noise margin reset to 6 which may give the small speed increase you are looking for  http://bt.custhelp.com/app/contact_email/c/4951
Message 3 of 3
As imjolly has posted you will get 88.2% of your connection speed for your IP profile which will give you approx 12552k your IP profile changes immediately with any change of connection speed either up or down
