Message 1 of 5
Broadband signal drops out when landline in use
help please, our broadband stops working when we use the landline to make a call. Adsl splitter has been changed and has not solved the problem, we have the router and main phone plugged into the splitter all other phones are wireless. Now becoming a real problem
4 REPLIES 4
Message 2 of 5
Re: Broadband signal drops out when landline in use
Does the broadband drop connection when you receive a call?
have you tried using the test socket with a new filter and see if it still happens
Message 3 of 5
It drops out whether we make or receive a call, and we have no test socket.
phone line works fine and broadband works as long as phone is not in use
Message 4 of 5
if dropping connection when phone rings that sounds like high resistance fault which you need to report a phone fault to 151 with no mention of broadband
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
http://www.kitz.co.uk/adsl/connectionprobs.htm
Message 5 of 5
Thanks for your help. The problem seems to have solved itself without me taking any action, and the landline is also much clearer. Open reach were in the area recently so may be whatever they gave done has solved it, who knows.
